2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Fixes for yacc code in Base?!
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 25 May 2023 21:09:31 -0500
On 5/25/23 10:42 AM, Ralph Lange via Core-talk wrote:
Recently activated new rules in our ITER software QA system have me go through EPICS modules once again, trying to make them pass quality gates.
Is it worth fixing smallish things in the yacc sources inside libCom, or should I just tag them as 'won't fix' in our static analysis application?
I'm happy to provide pull requests, but only if they have a chance to be approved.
My main concern now with changing the flex and antelope sources is that we don't have comprehensive unit tests that could detect changes that subtly affect their functionality. The things that the QA tools want should be acceptable as long as they stay small and localized.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Fixes for yacc code in Base?! Ralph Lange via Core-talk
Prev: Re: Fixes for yacc code in Base?! Michael Davidsaver via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-933 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
ANJ, 26 May 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
