2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: STATIC_BUILD=NO howto ?
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Tue, 13 Jun 2023 10:41:44 +0200
Hej Torsten,
Your error looks like you didn't declare the location of the vendor library.
Did you set Vendor_DIR?
If the build system doesn't find the library in a specified place, it assumes it is to be generated locally. That's why it tries to build a local libVendor.a, as it would need that to create a local libVendor.so.
Cheers,
~Ralph
Re: STATIC_BUILD=NO howto ? Torsten Bögershausen via Core-talk
Prev: STATIC_BUILD=NO howto ? Torsten Bögershausen via Core-talk
Next: Re: STATIC_BUILD=NO howto ? Torsten Bögershausen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
ANJ, 13 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
