2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: pC_->doCallbacksEnum() coming too early
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Torsten Bögershausen <tboegi at edom.se>, Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Thu, 29 Feb 2024 16:18:54 +0000
Hi Torsten,
As an aside, the recommended solution to remove this warning:
/* This version gives:
    warning:
       'rset' is deprecated [-Wdeprecated-declarations]
     rset            *prset;
Is to add
USR_CPPFLAGS += -DUSE_TYPED_RSET
to your Makefile and do any necessary code conversions/fixes that this might trigger; in this case there probably won't any needed though.
- Andrew
Complexity comes for free, Simplicity you have to work for.
pC_->doCallbacksEnum() coming too early Torsten Bögershausen via Core-talk
Re: pC_->doCallbacksEnum() coming too early Johnson, Andrew N. via Core-talk
RE: pC_->doCallbacksEnum() coming too early Mark Rivers via Core-talk
Re: pC_->doCallbacksEnum() coming too early Ralph Lange via Core-talk
Re: pC_->doCallbacksEnum() coming too early Torsten Bögershausen via Core-talk
Prev: Re: pC_->doCallbacksEnum() coming too early Torsten Bögershausen via Core-talk
Next: Build failed: EPICS Base 3.15 base-3.15-102 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Next: RE: pvAccess assert error Mark Rivers via Core-talk
ANJ, 29 Feb 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
