On 8/26/26 6:32 AM, Ralph Lange via
Core-talk wrote:
Feel free to add a comment to #943.
Temperature increases must be detectable by the frogs.
Testing would be appreciated.
https ://github.com/epics-base/epics-base/pull/949
Thanks
for the fast answers.
After updating EPICS base I can reproduce the problem here.
It seems to be a caput to a stringout record, which kills the
business.
/Torsten
On 2026-08-26 14:21, Ralph Lange wrote:
> Might be https://github.com/epics-base/epics-base/issues/943
<https://
> github.com/epics-base/epics-base/issues/943>
> On Wed, 26 Aug 2026 at 14:17, Simon Rose via Core-talk
<core-
> talk at aps.anl.gov
<mailto:core-talk at aps.anl.gov>>
wrote:
> Hi Torsten -
> Yes, I think I see the same thing. We actually saw it
last week
> during the training at ESS but blamed it on network
issues.
> This can be replicated on the 7.0 branch of
epics-base quite
> easily: start an IOC and try (for example) to use
caput to write to
> any record. In the IOC shell I see
> CAS: forcing disconnect from 172.18.22.141:59117
> <http://172.18.22.141:59117>
> And from the terminal trying to write to the IOC with
caput I see
> $ ./caput record_name 1
> Old : record_name 0
CA.Client.Exception...............................................
> Warning: "Virtual circuit disconnect"
> Context: "172.18.22.141:5064
<http://172.18.22.141:5064>"
> Source File: ../cac.cpp line 1241
> Current Time: Wed Aug 26 2026 14:15:06.470965000
> Context: "op=0, channel=record_name,
type=DBR_TIME_DOUBLE,
> count=1, ctx="172.18.22.141:5064
<http://172.18.22.141:5064>""
> Source File: ../getCopy.cpp line 91
> Current Time: Wed Aug 26 2026 14:15:06.471381000
> Warning: "Identical process variable names on
multiple servers"
> Context: "Channel: "record_name", Connecting to:
> 172.18.22.141:5064
<http://172.18.22.141:5064>,
Ignored:
> 192.168.205.1:5064
<http://192.168.205.1:5064>"
> Source File: ../cac.cpp line 1324
> Current Time: Wed Aug 26 2026 14:15:06.475347000
> Read operation timed out: PV data was not read.
> New : record_name
> Something is wrong here...
> Cheers,
> Simon
> *From: *Core-talk <core-talk-bounces at aps.anl.gov
<mailto:core-talk-
> bounces at aps.anl.gov>>
on behalf of Torsten Bögershausen via Core-
> talk <core-talk at aps.anl.gov
> *Date: *Wednesday, 26 August 2026 at 13:59
> *To: *core-talk at aps.anl.gov
<core-
> talk at aps.anl.gov
> *Subject: *github ci problem: CAS: forcing disconnect
from
> 127.0.0.1:57020
<http://127.0.0.1:57020>
> Hej EPICS-experts,
> since some time (July 10 2026 or 2026-07-10) we have
a failure
> on one of our github runners.
> If someone wants to look, here is a good run:
> <https://urldefense.us/v3/__https://github.com/
> EuropeanSpallationSource/m-epics-ethercatmc/actions/
> runs/29092838578__;!!G_uCfscf7eWS!
Zp_A98G8tvAmH3xmEtRxKFl_0Ydm7Wz0MSRmQ1ZrULhuV4JUEssosb0rF6Cv3MthfRkOlH0LmK79aHPdMb8$
<https://urldefense.us/v3/__https://github.com/EuropeanSpallationSource/m-epics-ethercatmc/actions/runs/29092838578__;!!G_uCfscf7eWS!Zp_A98G8tvAmH3xmEtRxKFl_0Ydm7Wz0MSRmQ1ZrULhuV4JUEssosb0rF6Cv3MthfRkOlH0LmK79aHPdMb8$>
> One of the failing runs is here:
> runs/32959143825/job/98147389788__;!!G_uCfscf7eWS!
Zp_A98G8tvAmH3xmEtRxKFl_0Ydm7Wz0MSRmQ1ZrULhuV4JUEssosb0rF6Cv3MthfRkOlH0LmK79fn7GMoM$
<https://urldefense.us/v3/__https://github.com/EuropeanSpallationSource/m-epics-ethercatmc/actions/runs/32959143825/job/98147389788__;!!G_uCfscf7eWS!Zp_A98G8tvAmH3xmEtRxKFl_0Ydm7Wz0MSRmQ1ZrULhuV4JUEssosb0rF6Cv3MthfRkOlH0LmK79fn7GMoM$>
> Of course the tests run fine here on a local machine
> (with probably sighly different versions)
> So digging into the log file shows one problem:
> Wed Aug 26 11:21:03 UTC 2026
> + ./runTests.sh ca://IOC:m1 100_Record-HOMF.py
> CAS: forcing disconnect from 127.0.0.1:48202
<http://127.0.0.1:48202>
> #... and later, PYT stands for the output of pytest:
> PYT:2026-08-26 11:21:04 AxisCom get ca://IOC:m1.VAL
ret=100.11
> PYT:2026-08-26 11:21:04 AxisCom get ca://IOC:m1.DMOV
> PYT:cannot connect to IOC:m1.DMOV
> PYT:2026-08-26 11:21:09 AxisCom get ca://IOC:m1.DMOV
ret=None
> Before I try to set up a system with the hopefully
exact versions as
> on github:
> Does a bell ring for anybody here ?
> The commits in EPICS base show that some additional
checks had been
> introduced when processing channel access messages in
rsrv
> However, we are using pyepics inside the test cases,
which uses
> the libca from base, so things should work.
> (And yes, Timo, we are using mostly pvacess for 99%
of the tests)
> Any ideas are welcome
> Best Regards
> /Torsten
- Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Ralph Lange via Core-talk
- github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Torsten Bögershausen via Core-talk
- Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Simon Rose via Core-talk
- Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Torsten Bögershausen via Core-talk
2025
<2026>
2025
<2026>
ANJ, 26 Aug 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
