<1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Building EPICS
Date: Wed, 6 Apr 94 09:54:01 MDT
Here are my R3.11 EPICS Build Notes.
R3.11 BUILD NOTES
additions to README.INSTALL :
 a.  You need to "sccs delget archUNIX" after you modify archUNIX.
 b.  config/sun4/sun.cf contains compiler specific information.  If
     you don't have gcc, specify the path to an ansi compiler in this
     file.
 c.  Bison/Flex need to be obtained from the gnu distribution.  They
     exist on ftp.uu.net in /packages/gnu.
           - NOT NECESSARY IN 3.12
BUILDIT
 a.  Unix/share/bin/Buildit contains a fixed directory for imake.  There
     are two imake commands in this file, redirect them to where your imake
     program exists.
           - FIXED IN 3.12
 b.  The Unix/share/bin directory has to be in the epics user's path
     so Buildit will run.
 c.  When Buildit is performing make depends on the vxWorks side, the
     following message may appear repeatedly:
.../../../share/vw/h/types/vxCpu.h: 102: undefined control
     Ignore these messages, and the compile should work.
           - I FIXED THIS FOR 3.12, Buildit uses the CORRECT compiler
                 now for dependencies.
   Matt
Note that Unix/share/bin/Buildit is supposed to be used by BOTH vxWorks
and Unix sides of the compile.
I also sped up the 3.12 build.  Now /bin/arch does not have to be run twice
every time a file is compiled.
I added support for mv162(LC) and niCpu030 targets in the config directory.
       Final note -  Of course, Mike Bordua from Berkeley is planning
                 to restructure the EPICS build so some of this may no
                 longer be relevant.
Prev: Modicon Support Bob Dalesio
Next: Re: Release 11 installation Jeff Hill
Index: <1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
