<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: errToLogMessage
Date: Mon, 2 May 94 10:12:04 MDT
Hello all,
For 3.12 we intend to change the default value of the vxWorks
variable "errToLogMessage" to true. This will cause all output
from the EPICS error logging routines to go to the vxWorks
routine logMsg() and not printf() by default.
Expected impact to systems that have taken the default value
for this parameter:
1) When two vxWorks tasks issue an error message at the same time the
output to the console will not be scrambled.
2) EPICS error messages will end up in the EPICS log file maintained
by the EPICS log server.
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM USA 87545	FAX		505 665 5107
Prev: Re: applications that use channel access winans
Next: Re: errToLogMessage John R. Winans
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: applications that use channel access Jeff Hill
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
