<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Limits on CA message size?
Date: Thu, 12 May 94 13:41:42 PDT
EPICS as shipped has a 16K byte buffer.  Thus you can only ship an
array of 4000 floats or ints.  At LBL we have changed the single
#define to increase this to 32K bytes to accommodate 8000 floats.  Jeff
or Marty can confirm this, but it appears and is logical that every
connection will have the bigger buffer. Thus, if you anticipate a peak
of 100 client connections for a given IOC, you will have added
16K*100=1.6MB of dynamics RAM allocation.
Note that some clients like dm carefully keep only one connection per IOC.
Others may not.  Again, Jeff and/or Andy can confirm what the demand is
for each instance of a sequencer:  It uses CA but not TCP/IP, therefore,
it may be smart enough to not need the buffer.
Steve Lewis
Prev: Problems with GDCT greene%denali.UUCP
Next: Re: Limits on CA message size? Andy Kozubal
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Limits on CA message size? mcgehee
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
