<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: BITBUS and PC's
Date: Thu, 9 Jun 1994 18:20:14 -0400 (EDT)
Tim Mooney writes:
>> Every week I hear from someone wanting to use a PC as an IOC, either to
>> preserve an existing hardware/software investment, or to take advantage
>> What would it cost to port EPICS to VxWorks on a PC?
Jeff Hill responds:
> The port would require changes to the CA server to swap the bytes in
> each of the structures in db_access.h. Part of this code already
> exists in the VAX CA client library. There is also some byte swapping
> in the socket interface and the CA protocol that would need to be
> handled.
In this topic, Tony Cox suggested that if we begin to use little-endian CA
servers (e.g. Intel, AXP) as well as little endian clients (Intel, AXP, VAX),
that CA should be changed to support intelligent handling of byte-order.  This
means that a little-endian server communicating with a little- endian client
should not convert everything to/from big-endian format on the network. I
think this is an excellent idea, and is, I think, how the X Windows protocol
works.
______________________________________________________________________
Mark Rivers                             (312) 702-2279 (office)
CARS                                    (312) 702-9951 (secretary)
Univ. of Chicago                        (312) 702-5454 (FAX)
5640 S. Ellis Ave.                      (708) 922-0499 (home)
Chicago, IL 60637                       [email protected] (Internet)
Prev: Re: BITBUS and PC's Jeff Hill
Next: Re: BITBUS and PC's Tim Mooney
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
