Subject: |
Re: Changes to Stepper Motor Record |
[email protected] (Joseph P. Sullivan) |
Date: |
Tue, 28 Jun 94 09:47:22 CDT |
Andrew writes:
> Various people have been talking about making modifications to the stepper motor
> record. Would anyone doing this have time to add a couple of enhancements which
> probably have widespread use?
If there are other motor control features that would be useful please let me know.
> 1. Simulation fields - as far as I can make out this record type only works when
> there is hardware present.
The only problem I have found with running the record without motors(assuming OMS
boards) is when the board is configured for active high limit switches. The limit
switchs can be disabled in software so implementing this feature should be
straight foreward. A workaround is to change the limit switch configuration to
active low (jumpers in).
> 2. Support for the Home sensor (datum switch), which I know can be connected to
> the OMS card.
The Home sensor function is already implemented in the 'new' motor record.
Joe
Joseph P. Sullivan Phone: (708) 252-8657
Experimental Facilities Division Internet: [email protected]
Argonne National Laboratory Fax: (708) 252-3222
9700 S. Cass Ave. Bldg. 362
Argonne, IL 60439-4844
Changes to Stepper Motor Record Andrew Johnson
Re: Channel access Jeff Hill
<1994>
2025
<1994>
2025
