<1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Need to use a board in various configurations.
Date: Mon, 11 Jul 94 11:42:35 PDT
Ned Arnold sez:
> How about having the driver allocate whether a byte is input or output
> depending on the first bit request for that octet. For example, if Bit 3 is
> specified in an input record (bi, mbbi), have the driver keep track that
> bits 0 thru 7 are inputs. If an output record later requests bit 7, issue an
> error message that this cannot be accommodated.
An interesting idea, altho assignment errors cannot be detected until
init-time.  I'll need to go look at the initialization process in detail
since I'm unsure exactly what gets tweaked at which time.
It seems like such a useful idea that it must violate some list of "Thou
Shall Not"'s or other.  (Sheeesh - it's so easy to be cynical on Mondays...)
John Winans adds:
> Lately, I have been writing drivers that require user configuration.
> So many features and options that just can't be represented by the DTYP
> field alone.  I use a function that in your case would have a name
> like VmiVme2534Config().  It would take parms used to cinfigure the
> board.  For your situation, I would have the following parameters:
> 1) The board link number to configure.
> 2) The board's base address is what ever address space it appears.
> 3) An IRQ vector and associated level.
> 4) A bitmask that describes the direction of data flow.
Hadn't thought about this approach.  Generally I like to try to avoid having
special invocations in the start-up file.
And then he adds:
> An alternate solution would be to leave the thing uninitalized and wait
> for the record init phase to decide what to do.  You COULD dynamically
> assign the data direction based on what the records are configured for.
> This is how the GPIB device support works with respect to knowing what
> devic addresses are used are attached to what links.
> Ahhh... I now see Ned thinks highly of the dynamic config idea too.
And Marty Kraimer chimes in with:
> The device init (NOT init_record) gets called twice at initialization time.
> The second time is after all records have been initialized. As each record
> calls the init_record entry of device support you could remember how each bit
> is being referenced by the records (you get bitt offset and number of bits).
> Then at the end configure the board. You can also look for conflicts and
> generate errors.
Yeah - I`m starting to think this may be the way to go for this particular
board.  We'll see what others have to add.
-bill
Prev: Re: Need to use a board in various configurations. mrk
Next: Re: Need to use a board in various configurations. Bill Brown
Index: <1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
