<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: APS Event Hardware
Date: Wed, 24 Aug 94 08:30:13 MDT
The software latency will be the sum of the interrupt latency (was 3us on a 68020) a context switch (was 30 usec on a 68020) and record processing (about
80 usec each on the 68040). Minimum latency is acheived by running the record from this on an event scan list at high priority. This is the highest priority
in the system. Only several vxWorks tasks run higher. The most devious one
being the shell task. If someone is logged in and invoking diagnostic routines,
then all bets are off.
The LANL timing hardware would also handle this problem. It has a 5 Mhz clock
and ~500 nansecond jitter. It is a much simpler design that the ANL timing as
it only has three types of events: no sequence RAM, no programmed events.
This proved adequate for our LINAC which was pulsed at 10 Hz. These boards
are relatively inexpensive, but not appropriate if you want to be generating
events at greater than 100 Hz. The limitation is in the software, not the
clock generator.
	Bob
Prev: RE: a friend in need Gabor Csuka, DESY - Germany
Next: RE: APS Event Hardware Frank Lenkszus
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: APS Event Hardware watson
