<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: request for status (2)
Date: Fri, 2 Sep 94 11:55:33 HST
I'm sorry but I forgot something...
5. Assuming (let's say) M68040-class IOCs, what is the fastest loop that one
   would normally close via database processing, ie via some sort of
   input record   --->   algorithm record   --->   output record
   chain? I just mean a ballpark figure. 1 Hz? 10 Hz? 20 Hz? Presumably one
   needs to consider two cases:
   a) all above database records on same IOC
   b) database records distributed across more than one IOC
   How much is the answer influenced by scan task priorities (assuming that
   CPU is not a scarce resource)?
William
Prev: Re: request for status Steve Lewis
Next: Re: request for status (2) mcgehee
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
