<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: CALC Records
Date: Mon, 7 Nov 1994 09:21:21 -0600
Such changes to the CALC record routines would impact things other than the
CALC records !  The handy routines "postfix" and "calcPerform" have been used
by other record types (at least two that I know of). So to say that such changes
could be implemented and the known effects minimized by a script that changes
CALC expressions in CALC records is quite dangerous.
If the problem is that the string reserved for the calculation is too short,
lets fix that (but since that is a channel access limitation, it will have to
wait until R4). If the problem is that you don't like the way the CALC is
specified, fix that with a different record type (e.g. "CCALC") and NEW
routines.
	Ned
Prev: Re: CALC records John R. Winans
Next: Re: CALC Records winans
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
