<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Infrequent I/O hardware
Date: Mon, 28 Nov 94 09:23:52 PST
One advantage of A-B (and its competitors, like Modicon) is that not
only are a wide range of input conditioning circuits available, but
generally clever packaging allows cards to be replaced with out
fussing with wiring. There is no hassle about front and back panels,
and everything is brought to screw terminals.  The mounting styles for
the enclosures allow a lot of choices and meet most electrical/fire
codes. For A-B, we also find the freedom to locate the terminating
wires independently from the VME (or VXI or CAMAC) an advantage in many
situations.  You can also put many "rack frames" on a single serial
line driven by one VME scanner, and they may all be dispersed quite a
distance.
As Chip mentions, there is a speed disadvantage, since the A-B scanner
polls at a relatively slow rate, about 10ms as I recall.  For new
installations with modest speed requirements and any sort of ruggedness,
I would choose it.  We used it here for the Bevatron and also for
Gammasphere.
We originally encountered some assumptions about even/odd addressing
built-in to the A-B drivers in EPICS that were no longer applicable for
later models, and Dalesio and his group were able to fix them very
quickly.  The experience and support from LANL gives A-B a definite edge
over direct competitors (Modicon, Siemans).  However, if you choose
similar hardware to CEBAF you will also get very strong support.
Steve Lewis
LBL
Prev: Re: IOC Boot Time winans
Next: re: digitizer boards Matthias Clausen DESY -MKV2/KRYK-
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Infrequent I/O hardware watson
Next: IOC Boot Time mcgehee
