<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MVME162's for remote I/O
From: Matthias Clausen DESY -MKV2/KRYK- <[email protected]>
Date: Thu, 01 Dec 1994 20:16:58 EST
>For your I/O you would (obviously) want to use some IP boards.  There
>are not any official EPICS drivers for them as far as I know.  DESY
>has been doing work in that area.  And there is always talk of them in
>the c.o.v group on usenet.
We (DESY) use the 162's as EPICS IOCs as well as intelligent I/O
controllers. In the first case EPICS; VXWorks(full function) and the driver
for the mounted IP-board are running on the same 162. In the second case
the 162 is an intelligent I/O controller running a reduced VxWorks kernel
and the driver to the IP-board.
All the software is the same in both cases. There's only a config file
which defines where the driver for the I/O is located on/off board.
The link between EPICS device support and the driver itself is performad by
the 'common driver interface' written by Gabor.
If the 162 is a slave you can use the smallest one available.
512kB will do but 1MB is better...
Currently the 162 slaves a booted through the VME backplane and the master
(167) from the SUN. We (Gabor) are working on a prommed version in which
case the board can run together with any other operating system in the same
VME crate.
Matthias
	Matthias Clausen		Deutsches Elektronen Synchrotron
	Gruppe: MKV2/KRYK		       DESY/Hamburg, Germany
Prev: Re: MVME162's for remote I/O winans
Next: CA library on the PC Matt Bickley
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
