<1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VxGDB question
Date: Thu, 22 Dec 94 09:01:15 MST
I want to use VxGDB to print the contents of a pointer which
points to a valid VXI memory location for a specific card.  I have found
that I can't use the "print *" option - I get the following error:
(vxgdb) print ptr
$1 = (int *) 0x20000000
(vxgdb) print *ptr
ptrace: Bad address.
Cannot read memory: address 0x20000000 out of bounds.
(vxgdb)
This appears to be a limitation with ptrace().  I need to
know *how* I can print the contents of pointers to VXI memory since I
apparently can't do it with "print *".  I would prefer using VxGDB to
do this is possible.  Any suggestions?
Thanks
                                    Greg Greene
                                   KineticSystems
                                 (303) 220-7455 x13
Prev: FWD: HELP FOR MY VISA TO USA Gabor Csuka, DESY - Germany
Next: EPICS R3.11 CA client library BUG Jeff Hill
Index: <1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
