1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Bug in DM using long records?
Date: Thu, 5 Jan 95 14:42:52 MST
> When I run up the display under DM, the limits on both the Valuator and
> Indicator are not the same as the High and Low Operating range of the record.
> If I move the valuator, the Indicator does not move, although it is obviously
> being refreshed.  However I can use cau to monitor the record and it shows it
> changing correctly to the Valuator settings. If I ask the DM window to refresh
The operation of valuators in DM has never been implemented for longin's. I
believe this is on Deb Kerstien's list of items to take care of for the next
release of DM. Your best bet is to use valuators with analog in's and place
the value of that ai into the longin of interest.
Sorry about the inconvenience.
Carl Timmer
LANL
Prev: Bug in DM using long records? Andrew Johnson
Next: Release 3.12 Memory usage Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Bug in DM using long records? Tim Mooney
