Subject: |
Work needing support |
[email protected] (Bob Dalesio) |
Date: |
Tue, 14 Mar 95 12:53:38 MST |
At the last collaboration meeting we discussed work that needs to be
done in EPICS and discussed ways to get it funded/handled. I think
the options are:
your institution will put in time to do the work,
contribute money to do the work,
no help can be given by your institution.
If you are willing and able to contribute to these topics, please let me know
and we will organize the work groups to set and accomplish the goals.
Bob
Coordination
Somone needs to coordinate these activities, track them,
predict the contents of releases, and minimize the
duplication of effort.
___________
System Administration:
maintain, document, and test installation and builds on:
Sun 4.1.3 ___________
HP UX ___________
Solaris ___________
VAX Aplha ___________ (CA/libCom)
VAX VMS ___________ (CA/libCom)
DOS/WINDOWS ? ___________ (CA/libCom) W'95, limux, OS@????
WINDOWS NT ___________ (CA/libCom)
note that each of these architectures uses some subset of what
is in the base and extensions
distribute and provide support for the next release
HP UX ___________
Solaris ___________
VAX VMS ___________
DOS/WINDOWS ___________ (CA/libCom) W'95, limux, OS@????
provide vxWorks support to those using the EPICS collaboration
vxWorks license:
initial installation _______________
ROM support _______________
support an application architecture that is
simpler _______________
Database Issues:
Configuration Tools
EDIF2SR modifications
-integrate new Capfast _______________
GDCT Extensions/Mods
- port to freeware _______________
DCT _______________
ATODB
- preload checking
- defaultdct.sdr _______________
Database
Integrate new records _______________
Online Add/Delete _______________
Redundancy _______________
Port it to UNIX _______________
ANSI C _______________
Device Support
Integrate new devices _______________
Improved device layer _______________
user defined bus type _______________
device specific parameters in
new db rec type _______________
Driver Support
Sane standard for address specification _______________
Integrate new drivers _______________
Convert drivers to ANSI C _______________
Add volatile to hardware overlays
so we can use optimizer _______________
Arch independent types hardware overlays_______________
Call devLib for addr map and conflict
addr detect _______________
Driver init order issues _______________
Channel Access Client Issues:
Device API _______________
cdev/channel access _______________
cdev/tcl _______________
cdev/ObjectStore _______________
cdev/ACE _______________
Sequencer Support _______________
Operator Interface DM/EDD
Thumbwheel Widget _______________
Extend Plot Capability _______________
Expression Support _______________
- value, color and visibility
Import GIF files _______________
Grouping _______________
3-D Frame Widget _______________
Modify selected objects _______________
Finish ANSI C convert _______________
Grid Align _______________
MOTIF look/feel _______________
Channel Access
Multi priority _______________
Portable Server _______________
New Protocol _______________
Name server _______________
User defined data types _______________
Name res cache _______________
Unlimited array _______________
Multi-dim array _______________
Improved test program _______________
Arb. data type _
Archiver
Collect Requirements _______________
Develop Functional Spec _______________
Develop Design _______________
Implement _______________
Callable retrieval _______________
MEDM
Encorporate good features from DM/EDD
Improve Plot Performance
Alarm Manager
Filters on Log Viewer _______________
PV Macro Substitution _______________
Support for Interpreters
tcl/Tk
IDL/PVWave
Matlab
GUS
GPIB
Keep GPIB repository (screens, database, device support)
_______________
Automation toolkit _______________
Improved error logging _______________
Low cost IOC _______________
Common Data Formats
SDDS _______________
HDF _______________
Documentation
Produce _______________
Provide WWW Repository _______________
versioning ioc startup scripts for a control system Johnny Tang
Re: R3.12 Environment Parameter system Andrew Johnson
<1995>
beta release problems Marty Kraimer
<1995>
