Subject: |
Re: dvx 2502 |
[email protected] (Jeff Hill) |
Date: |
Tue, 28 Mar 95 13:55:51 MST |
> While thumbing through the driver, I noticed
> the register map structure pads out to 128 bytes, while the board base
> addresses are selectable at 64 byte boundaries. Is there a particular
> reason why the driver was set up this way? We can save some short IO
> space by changing it.
Am I misssing something? It looks like it pads to a 64 byte boundary
to me.
struct dvx_2502
unsigned short dev_id; /* device id code (CFF5) */
unsigned short dev_type; /* type code (B100) */
unsigned short csr; /* control and status register */
unsigned short seq_offst; /* sequence RAM offset register */
unsigned short mem_attr; /* memory attribute register */
unsigned short samp_rate; /* sample rate register */
unsigned short dma_point; /* DMA pointer register */
unsigned short dma_data; /* DMA data register */
unsigned short thresh; /* threshold register */
unsigned short fifo; /* input fifo */
unsigned short end_pad[54]; /* pad to 64 byte boundary */
Jeff
DVX2502 addressing Claude Saunders
dvx 2502 Jeff Hill
<1995>
2025
dvx 2502 Jeff Hill
<1995>
2025
