1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: EPICS extensions porting to Solaris (native) and IRIX
Date: Mon, 15 May 1995 15:07:59 -0500 (CDT)
            Build of EPICS extensions on Solaris 2.4 and IRIX 5.2
                                  Update 2
                                May 15, 1995
Since my last post I have done a bit more fiddling and built more of the
extensions on Solaris (native port, no UCB compatibility) and IRIX.
The following table shows what things I was able to build in /extensions/lib
                        SunOS4.3        SunOS5.4       IRIX 5.2
libANLwidgets.a            X               X              X
libEdif.a                  X               X              X
libGraphX.a                X               X              X
libLca.a                   X               X              X
libMedm.a                  X               X              X
libPrintUtils.a            X               X              X
libSDDS1.a                 X               X              X
libUnix.a                  X               X              X
libdev.a                   X               X              X
libezca.a                  X               X              X
libezca.so.1.0             X               X              X
libgraphX.a                X               X              X
libgz.a                    X               X              X
libLseq5.a              needs gcc      needs gcc       needs gcc
libmdblib.a                X               X              X
libmenu.a                  X               X              X
libnamelist.a              X               X              X
libpprsyd.a                X               X              X
libprintUtils.a            X               X              X
librpnlib.a                X               X              X
libutil.a                  X               X              X
The following table shows what things I was able to build in /extensions/bin.
These were again built with only very minor modifications.  I will send the
changes I made to Janet Anderson so that they can be integrated with changes
others have made (for Alpha, HP, etc) and incorporated in a future release.
medm was built with Tony Cox's stubs for the Xrtgraph routines. I have tested
km with a SunDials box on a Solaris system and it works. km on the SGI does not
support a dial box yet.
What did not work:
- Any of burt tools. Compilation errors on all platforms.
- dm or edd on anything but sun4
- free_gdct or gdct. Requires interviews which I had not installed.
AR                         X               X            needs xview
ARR                        X               X            needs xview
ARR_cmd                    X               X               X
AR_cmd                     X               X               X
CaIDL.so                   X               X               X
CaMath                          requires Mathematica
CaTCL                           requires tk/tcl
CaWave.pro                 X               X               X
CaWave.so                  X               X               X
CaWidgets.pro              X               X               X
alh                        X               X               X
aps_wish                        requires tk/tcl
caGet                      X               X               X
caInfo                     X               X               X
caInfo1                    X               X               X
caPut                      X               X               X
caWingz                         requires Wingz
caget                      X               X               X
camonitor                  X               X               X
caput                      X               X               X
cau                        X               X               X
degauss                    X               X               X
devSend                    X               X               X
dm                         X
dp                         X               X               X
e2sr                       X               X               X
edb_filter                 X               X               X
edd                        X
getScopeSetup              X               X               X
idev_svc                   X               X               X
idl_startup.pro            X               X               X
km                         X               X               X
knobconfig                 X               X               X
medm                       X               X               X
motifButton                X               X               X
nlpp                       X               X               X
popup                      X               X               X
probe                      X               X               X
putScopeSetup              X               X               X
rampload                   X               X               X
run_tcl_select             X               X               X
runseq                     X               X               X
scandefs                   X               X               X
sendScopeCommand           X               X               X
setupidl                   X               X               X
setupseq                   X               X               X
sstask                     X               X               X
standardize                X               X               X
stripTool                  X               X               X
tcl_select                 X               X               X
xmca                       X               X               X
xmseq                      X               X               X
Prev: subscribe Hide Mizuno
Next: Anyone using fast ethernet in their IOCs? mcgehee
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: subscribe William C. Ross
Next: Re: EPICS extensions porting to Solaris (native) and IRIX Muranaka Masaki
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
