1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: compress records
Date: Thu, 25 May 1995 11:08:15 -0500
> From denali!greene Thu May 25 09:29 CDT 1995
> From: <greene%[email protected]>
> Subject: compress records
> To: <[email protected]>
> Date: Thu, 25 May 1995 08:25:00 -0600 (MDT)
> X-Mailer: ELM [version 2.4 PL24]
> Mime-Version: 1.0
> Content-Transfer-Encoding: 7bit
> Content-Type> : > text/plain> ; > charset=US-ASCII>
> Content-Length: 596
> Looking at the documentation and the source for the compress records, it
> looks like the input to this record is a single sample of NSAM channels.
> I need to be able to average a waveform record buffer but it appears that
> the compress record cannot do this.  Is this correct?  If so, is there a
> record type already defined that will do this?
> 				Greg Greene
> 				KineticSystems Corp.
> 				ph:  303-220-7455 x13
> 				fax: 303-220-7458
The following is taken from the record reference manual (compress record)
If NTO1LOW, NTO1HIGH, or NTO1AVE are chosen, then VAL is a cdircular
buffer of length NSAM. ... If INP refers to an array, then each time the
record is processed, the array referenced by INP is obtained, divided into
sub_arrays each of length N and the algorithm applied to each sub-array.
The result from each subarray is written to the circular buffer referenced
by VAL.
If all you want to do is average a waveform just set
NSAM=1
ALG = NTO1AVE
N = length of input array
Marty Kraimer
Prev: compress records greene%denali.UUCP
Next: VME bus confusion winans
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
