1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: re: VME bus confusion
Date: Thu, 25 May 1995 16:43:31 -0500
> 1) There MUST ALWAYS be a board of some kind in EVERY slot of the VME
>    crate starting on the left and working right.  If you MUST have
>    a missing board, you may simulate it by installing the BG and IACK
>    jumpers often found on the VME backplane.
>    Failure to follow this rule causes very strange things to happen.
>    Common sense does not seem to apply to this easier... don't think
>    that just because a board does not generate IRQs or operate as a bus
>    master that things will still be OK.  We have seen otherwise!
Not to throw grit in the gears of progress but the VME crate nearby has
a pretty wide gap between the few modules on the left side of the crate
and the MVME 162 coprocessor running HiDEOS.  Numbering from 0 at the
left of the crate, slots 0-5 are filled, 6-13 are empty, 14 is filled
(the 162), & 15-19 are empty.  No complaints from EPICS, VME, or ...
It seems to work.  Must be a miracle.  However, on reading the above
advice, this crate will be told to get with the program.
>     If anyone ever calls me again with a problem that is caused by
>     this... the service charge will be a 6-pack of Miller Highlife in
>     bottles.  Viva le Champaign of Beers!
> --John
This, too, can be arranged.
Pete
Prev: Re: VME bus confusion Tim Mooney
Next: EPICS Development, Distribution, and Support Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
