1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Building for more than one host architecture
From: "Tony Carter, MIT Bates Linac" <[email protected]>
To: [email protected]
Date: Mon, 5 Jun 1995 13:25:13 -0400 (EDT)
Is anyone out there building EPICS on more than one host arch at the same
time?  Our development machine configuration is:
	Alpha/DEC Unix - Client applications
	Sun/SunOS - Client applications & IOC core/applications
I want to have only one master copy of the EPICS development tree on an
NFS server to be mounted by various development machines.  Matt Needes
and Mike Bordua (et al) did a nice job of laying things out so that
object modules/executables/etc are kept seperate for different archs, so
I don't see a problem there.  But in ...config/CONFIG_SITE you must specify
only one host architecture for HOST_ARCH.  Swapping back and forth between
machine specific CONFIG_SITE's is not an option.
If there is no better solution, I can mount the base and extensions subdirs
off of the server seperately and have arch specific config subdirs to be
mounted as "config" on each development machine.  It just seems like there
should be a more intelligent solution.  Is there?
Thanks.
Tony Carter
MIT Bates Linac
Prev: UK mirror for EPICS documentation? David F. Buscher
Next: Task Delete of Sequence Crashes IOC Charles S . Higgins
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Building for more than one host architecture Mark Rivers
