In Message-Id: <[email protected]>,
Bob wrote,
>Hello Noboru,
> We have used the NI-1014 - but not with the Force 040. As
>I recall, this board uses DMA. Frequently this requires some
>modification to the memory configuration of the CPU.
> I hope everything is well. We are doing fine.
> Best Wishes,
> Bob
After I sent a question to tech-talk, we found the following fact:
1) NI-1014 DMA can access VME address in A24 mode.
2) To accesse Main memory on FORCE cpu40 via VME bus, address mode
should be A32 mode.
These facts means that the standard GPIB support routines in EPICS does not
work for this combination of boards. We happened to have memory board for VME
bus and allocated buffer space GPIB driver on this memory board. After that,
GPIB support routines are working.
Noboru Yamamoto
KEK, Accelerator Dept.
- Re: Q: NI-1014 GPIB board with Force CPU40. Kazuro FURUKAWA
Re: output record initialization Gordon Uchenick
Re: output record initialization watson
<1995>
Q: NI-1014 GPIB board with Force CPU40. Noboru Yamamoto
<1995>
