> This problem has already been address and Jeff has corrected it for the
> next release, in the mean time, attached is the corrected file.
While I suspect that the cadef.h source file recently distributed on the
exploder will work correctly with any 3.12 release I would recommend
installing the changes I supplied in my last letter rather than
installing 3.12.2's cadef.h verbatim.
In either case I recommend that if you change cadef.h you should
recompile the ca client library and all of the clients that use it.
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
Re: Epics C++ Problems Jeff Hill
XY240 mystery.... Bonnie Montjar
<1995>
2025
What th??? (was: Re: Epics C++ Problems) John R. Winans
<1995>
2025
