Ian wrote:
> I've just started to use ar and can't get my script to work properly:
> DESC: test it
> ACT: always
> INACT: never
> TRIGGER: every 0:0:5
> SNAPSHOT: for 1 samples
> OUTPUT: set:txt ar/arSet/test.txt
> %endHeader%
> ser2:emosub_44.VALA
> It validates ok and when added to the main pannel successfully gets its
> first sample: 'snapshot complete...' and data is written to the file. It
> then says: 'snapshot sampling...' but never gets anything. If I ask for
> status|show sampling state it saya: 'snapshot in progress; 0 samples,
> last at 00:00:09.000'
> the ADEL for the record is set to 0.
> Anybody have any ideas?
> thanks
> Ian A Smith Telephone: +44 (0) 131 668 8257
> Royal Observatory Fax: +44 (0) 131 668 1130
> Blackford Hill Web: http://www.roe.ac.uk/
> Edinburgh
> UK
Rozelle wrote:
>The archiver won't take samples unless ser2:emosub_44.VALA is changing.
>I think this is a bug, but it is the way it works. If you
>want to take samples where some channels are changing and some are not,
>you can put F (for fill) in front of the ones that are not changing .
>For example if you have a counter calc record named "counter"
>that is being scanned (and changed) more often than once every 5 seconds
>the following should get samples
I agree that you must have at least one chan specified that is returning
monitors frequently enough to meet your sample time.
One additional note: for processing to return data based on ADEL even when
no change has occurred, ADEL must be set < 0.0 for analog-type data.
The comparision is done on a delta > 0.0 (not >=0.0).
Deb
Deb Kerstiens [email protected]
Phone (505)667-3396
LANL AOT-8,MSH820 PO Box 1663, Los Alamos, NM. 87545
Re: application error codes Jeff Hill
<1995>
Re: help with ar Rozelle Wright
MBBO record support Peregrine McGehee
<1995>
