1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Has anyone integrated the Heurikon "Nitro 60"
To: [email protected]
Date: Mon, 6 Nov 95 08:30:33 MST
We have been using the Heurikon Nitro60 at Los Alamos for about six months with
excellent results. We have also seen the sysfail problem, but standard procedure
here is to cut the trace on boards which do obey the specs. We have no trouble
with the BSP (our vxWorks is supplied by Wind River). I have used it with most
A16 and A24 I/O boards we are currently using with few glitches. For me, it was
an exceptionally easy port. The only "features" we have found disagreable to
date are:
	1) For slave DMA access to A24 space, only 2Mb of local RAM is mappable.
	   Heurikon claims they can fix this. Slave access to A32 space does not
	   have this problem.
	2) If the console serial port is connected to an inactive (but powered
	   up) port, the boot process will hang. This occurrs most frequently
	   with a workstation connected but no terminal emulator running.
	3) The BSP as supplied by Heurikon reserves the first 32Mb of extended
	   address space for on board resources regardless of how much RAM is
	   actually there. We have a few A32 boards whose base addresses had to
	   be moved.
	Matt Stettler
Prev: Re: Has anyone integrated the Heurikon "NITRO 60" 415
Next: Re: Has anyone integrated the Heurikon "NITRO 60" Matthew Stettler
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
