This mail is made of the recycled electrons
Mailer: Elm [revision: 70.85]
R3.12.2 epics source for HP port is now available from
CEBAF ftp site with the password.
To obtain the password,
i) you must be a part of EPICS collaboration or
you must have an agreement with the collaboration
(Bob Dalesio [email protected])
ii) e-mail [email protected] a request or
fax (804)249-7049
iii) call (804)249-7239
> The USER name is XXXXXXX
> The PASSWD is XXXXXXX
> The DIR is XXXXXXX
> Instructions for use:
> Anonymous ftp directions for sublogins April 1995
> Here are some instructions for the anonymous ftp users with sublogins:
> NOTE: Substitute the username you were given where ever you see USER.
> Substitute the password you were given where ever you see PASSWD.
> Substitute the directory you were given where ever you see DIR.
> First FTP to our site. Type the following
> $ ftp ftp.cebaf.gov
> Then you will login as anonymous. Type anonymous at the prompt.
> Connected to cebafh.cebaf.gov.
> 220 cebafh FTP server (Version 1.7.193.3 Thu Jul 22 18:32:22 GMT 1993) ready.
> Name (ftp.cebaf.gov:USER): anonymous
> Then you will supply your email address as a password (It is not echoed back).
> 331 Guest login ok, send ident as password.
> Password: [email protected]
> You are now logged into our site via anonymous ftp
> 230 Guest login ok, access restrictions apply.
> Remote system type is UNIX.
> Using binary mode to transfer files.
> ftp>
> Change to the DIR directory.
> ftp> cd DIR
> 550 DIR: Permission denied.
> It did not work because user anonymous does not have the correct permissions.
> You must do a sublogin to a user that can access this directory.
> Change to the appropriate user.
> ftp> user
> (username) USER
> 331 Password required for USER.
> Password: PASSWD
> 230 User USER logged in.
> Check your current directory.
> ftp> pwd
> 257 "DIR" is current directory.
> ftp>
> This will change your current working directory to the users home directory.
> In your case the users home directory is DIR. The user will
> always be placed in the DIR directory after executing the user
> command. They can then use the put or get command successfully.
Johnny Tang Voice: (804)249-7239 E-Mail: [email protected]
Continous Electron Beam Accelerator Facility
12000 Jefferson Avernue, MS 85A
Newport News, Va 23606
bug in ca_array_get() when the data type is string Jeff Hill
SOlaris developer's package and 147 BSP Bob Dalesio
<1995>
<1995>
