1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Displaying waveforms
To: [email protected]
Date: Fri, 26 Jan 96 01:51:27 PST
Hi guys:
If you have the time could you answer a question?
Why would the following code fragment not work?
double waveform_array[16384];
assign waveform_array to "WAVEFORM_ARRAY.VAL";
/****** Acquire data and stuff it into an array: this part  *****/
/****** works because I can print out believable data using *****/
/****** the printf statement below.                         *****/
/* write to waveform */
%%	array1_ptr=lpanarray1;
%%	for(count=0;count<lnumsamples;count++)
%%		waveform_array[count] = (double)(array1_ptr[count]*3.091e-10);
%%		printf("%e\n",waveform_array[count]);
	pvPut(waveform_array);
My database file for this record looks like this:
    record(waveform, "WAVEFORM_ARRAY")
        field(DESC, "Array for HP positions")
        field(SCAN, "Passive")
        field(PINI, "NO")
        field(PHAS, "0")
        field(EVNT, "0")
        field(DTYP, "Soft Channel")
        field(DISV, "1")
        field(SDIS, "0")
        field(DISS, "NO_ALARM")
        field(PRIO, "LOW")
        field(FLNK, "0")
        field(RARM, "0")
        field(PREC, "4")
        field(INP, "0")
        field(EGU, "nm")
        field(HOPR, "1.0e-08")
        field(LOPR, "-1.0e-08")
        field(NELM, "16384")
        field(FTVL, "DOUBLE")
        field(SIOL, "0")
        field(SIML, "0")
        field(SIMS, "NO_ALARM")
Instead of putting this array into my waveform record, the dang computer
prints the error message:
error from CA on WAVEFORM_ARRAY.VAL
The array or data structure specified will not fit in CA message buffer
Any ideas what's wrong? Thank you very much!
John Spring
Prev: Re: request to modify db_name_to_addr for USHORT mapping Marty Kraimer
Next: EPICS Master Tree Developers Marty Kraimer
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Displaying waveforms Marty Kraimer
