1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: bus crashes
To: [email protected]
Date: Thu, 8 Feb 1996 14:43:48 +0000 (GMT)
I was developing a small database and started to get consistent bus crashes:
Bus Error
Program Counter: 0x0000879c
Status Register: 0x3008
Access Address : 0x404d0000
Special Status : 0x04a5
Task: 0xe50e54 "scanPeriod"
task: 0Xe786ac taskwd
I took out all my mods to the point before they started appearing but
they did not go away.  I tracked down the line of code that caused them
(in my sub record c code) and it turned out to be the vxWorks 'read'
function.  I checked all the parameters in the call and they are fine.
(the read is reading from a tcp socket, not a disk etc).  I thought it
unlikely to be vxWorks so I tried it in another crate and the error
disappeared, -> hardware error.
I removed the cpu and pressed all the sockets etc but that hasn't
helped.  The other funny thing is that this application also caused a bus
error a few weeks ago in the crate that it now works in, but that problem
was left unfinished rather than being tracked down.
So, the upshot is that we appear to have transient hardware errors in our
systems.
Has anyone come across this before, is there a particular connector that
exhibits this behavour? (mv167)
thanks
Ian A Smith			Telephone: +44 (0) 131 668 8257
Royal Observatory		Fax:       +44 (0) 131 668 1130
Blackford Hill			Web:       http://www.roe.ac.uk/
Edinburgh
EH9 3HJ
UK
Prev: Re: EPICS PLC Support Dr. Pete Jemian
Next: Re: macro substitution Marty Kraimer
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: [no subject] Jim B. Kowalkowski
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
