1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Q] X-window's Graphics context
To: [email protected]
Date: Wed, 21 Feb 1996 13:47:46 +0100
>>>>> "Noboru" == Noboru Yamamoto <[email protected]> writes:
  Noboru> Hi, Friends:
  Noboru>  When I was compiling edd/dm with EPICS3.12.2, I got a compiler
  Noboru> error related to X-window's Graphic context structure.  Some
  Noboru> routines access access directly "value" field of GC structure.
  Noboru> Compiler claims that there is NOT such field. Sure enough,
  Noboru> /usr/include/X11R4/X11/Xlib.h file on our machine (HP-UX 9.05)
  Noboru> defines GC as follows:
I discovered the same problem in some(? I don't remember, sorry) places.
The point is, that the whole structure (resp. the 'value'-field) is now
(since X11R5? at least on HPs) part of the 'internal' (that means internal
X-structures) header-file. So I simply included '<X11/Xlibint.h>' in the
appropriate source-files and it worked fine.
     ________
Ciao, /homas
_______________________________________________________________________________
 Thomas Birke  BESSY II  (+49)-30-6392-4934 (fax -4859)  [email protected]
[Q] X-window's Graphics context Noboru Yamamoto
Prev: [Q] X-window's Graphics context Noboru Yamamoto
Next: Re: [Q] X-window's Graphics context Andrew Johnson
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
