1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: logging writes
To: [email protected], [email protected]
Cc: [email protected]
Date: Fri, 23 Feb 96 09:50:56 MST
> In addition it would help if any write action to the IOC's could be logged on a
> file. This would help to keep track and analyse problems. This would need an
> output channel from the CA-server on the IOC to a (i.e.) NFS-mounted disk.
> The output would look like:
> date time user@machine changed record from value to value
I think that this is a good idea.
Here are some issues that will need to be resolved:
o I assume that the default would be to log writes to the log server? Hooks
would be provided so that a site could choose to replace this default
(and reroute the information to another destination).
o Note that there will often be time periods when there are many writes
(ie someone moves a valuator etc). In practice we may decide that only the
last write in a given time period should be sent to the log. Does this imply
that we will need a configuration parameter that selects a write log period?
o Will we need to enable this feature only for particular records/fields?
o Since this would be logging significant changes it sounds like possible
infrastructure for generalized backup and restore could be lurking here?
o Does this functionality belong in the ca server or should it be implemented
by each server tool? My initial thought is that implementing this in the server
lib will minimizes lines of code. All configuration information would
of course be obtained from the server tool.
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: sequencer Loren Shalz
Next: Logging of Write Actions 415
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sequencer Andy Kozubal
