1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: dm display arguments declaration
To: [email protected]
Date: Fri, 23 Feb 96 11:46:18 MST
hello all,
I am thinking that we should add display arguments declaration to
"modify display attributes" in edd. This would be a single
parameter with the following syntax:
"<arg0> {= <default>} , <arg1> {= <default>} , ..."
example:
"BPMNO = 1, SECTOR = blue, BLDG"
In this case when starting the display if they dont specify a value
for the macro "BPMNO" then the value assigned will be "1". If they
dont specify "SECTOR" then the value "blue" will be assigned.
If they dont specify "BLDG" then they will be prompted for this
argument via a dialog box.
For backwards compatibility (and convenience) if the display
arguments declaration isnt provided (is empty) then dm would continue
to operator as it does today (without argument checks).
I see three main advantages to this approach:
o better error messages if the arguments are over/under specified
o optional defaults for arguments (allows adding new arguments to a display
without breaking preexisting callers of the display)
o the possibility of prompting for missing arguments via a dialog box
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: Re: Logging of Write Actions watson
Next: Re: dm display arguments declaration William Lupton
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
