1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DEC Alpha OSF-1 generated database
To: [email protected]
Date: Wed, 28 Feb 1996 08:24:15 -0600
Ralph Quan wrote:
> Has anyone been loading Alpha OSF-1 generated databases
> on controllers like the mvme-167 ?
> There seems to be an endianness problem, and Tony Cox
> was temporarily using a stand-alone conversion program
> to do byte swapping after the database creation.
> Any details concerning this conversion program would
> be greatly appreciated.
> Ralph Quan
> KineticSystems Corporation
> (303)220-7455 x14
Since no one responded I will try.
My guess is that for the current official release of epics you are
out of luck. You can, however, do the following:
1) Prepare a default.dctsdr of a big endian machine (sun or hp
   work for sure). Load this into ioc with dbLoad before loading
   any record instances.
2) Prepare all record instances in the gdct .db format, which is
   completely ascii. This can be loaded with dbLoadRecords and/or
   dbLoadTemplates.
In the next release of epics ALL database definition files will
be loaded from ascii files, i.e. default.dctsdr will go away.
At this time the big vs little endian problem disappers for
ioc epics databases.
Marty Kraimer
DEC Alpha OSF-1 generated database Ralph Quan
Prev: Anyone using Tornado yet? Peregrine McGehee
Next: Stepper motors Ric Claus
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: DEC Alpha OSF-1 generated database Ralph Quan
Next: Who is currently maintaining arr aka arrtk? Joseph LaSalle White
