1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem changing to use ASCII database
To: [email protected]
Date: Wed, 27 Mar 1996 08:45:52 -0600
Here is the problem:
sf2db passes along PP or NPP IF it is defined. If neither PP or NPP
is defined then the .db file will not have it defined.
If the .db file does not have have PP or NPP defined,
NPP is the default.
This default is made by the Static Database Access Library,
which can not be changed without causing problems for non-capfast
users.
If DCT reads in a short form report that does not have PP .or NPP
defined the default is PP.
Thus if CAPFAST Users do not define PP on pv links there will
be a different result using dct to convert the short form report
vs using sf2db.
In hindsite the default for capfast users should also have been
NPP. Since capfast users relied on dct to convert short form reports,
the default become PP.
What to do??
Marty Kraimer
Date: Tue, 26 Mar 1996 14:10:57 +0000 (GMT)
Subject: Problem changing to use ASCII database
Message-Id: &lt;Pine.SOL.3.91.960326140356.15828F-100000@hobbit&gt;
I have just changed over from using the old type EPICS
database loading to use ASCII databases, using sf2db
to generate the .db files. I used the same original
Capfast schematics as before.
My system stopped working - even though I was using the same
short-form report to generate the old and new (ASCII) databases.
It eventually turned out that links that had previously
defaulted to be Process Passive have now become Non
Process Passive when loaded from an ASCII database file.
So has some default changed - and how do you ensure that
links are process passive now?
Philip
Philip Taylor, Royal Greenwich Observatory,
Madingley Road, CAMBRIDGE. CB3 0EZ. UK
Email : [email protected]      Phone : (UK+) (0)1223-374710
Re: Problem changing to use ASCII database watson
Prev: Problem changing to use ASCII database Philip Taylor
Next: Re: Problem changing to use ASCII database watson
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
