1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem changing to use ASCII database
To: [email protected]
Cc: [email protected]
Date: Wed, 27 Mar 96 08:43:34 MST
> From [email protected] Wed Mar 27 07:47:15 1996
> Return-Path: <[email protected]>
> Sender: [email protected]
> Date: Wed, 27 Mar 1996 08:45:52 -0600
> X-Mailer: Mozilla 2.01 (X11; I; SunOS 5.4 sun4m)
> Mime-Version: 1.0
> Content-Type> : > multipart/mixed> ; > boundary="------------4DE8112158A7">
> Content-Length: 2168
> X-Lines: 68
> This is a multi-part message in MIME format.
> --------------4DE8112158A7
> Content-Type: text/plain; charset=us-ascii
> Content-Transfer-Encoding: 7bit
> Here is the problem:
> sf2db passes along PP or NPP IF it is defined. If neither PP or NPP
> is defined then the .db file will not have it defined.
> If the .db file does not have have PP or NPP defined,
> NPP is the default.
> This default is made by the Static Database Access Library,
> which can not be changed without causing problems for non-capfast
> users.
> If DCT reads in a short form report that does not have PP .or NPP
> defined the default is PP.
> Thus if CAPFAST Users do not define PP on pv links there will
> be a different result using dct to convert the short form report
> vs using sf2db.
> In hindsite the default for capfast users should also have been
> NPP. Since capfast users relied on dct to convert short form reports,
> the default become PP.
> What to do??
> Marty Kraimer
I'm not sure about other sites, but here at Los Alamos, all of our capfast symbols
have pproc(<for every link where it matters>) set to NPP, so the change won't affect
us at all.  I think most places using capfast got their symbols from us, so
it should not be a real problem for capfast users.  It is a problem for people
who made their databases directly from dct.
Rozelle
Re: Problem changing to use ASCII database Marty Kraimer
Re: Problem changing to use ASCII database Philip Taylor
Prev: Re: Problem changing to use ASCII database watson
Next: Re: Problem changing to use ASCII database Marty Kraimer
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
