While playing around with the `mbbiDirect'-record, we encountered the
problem, that the corresponding bits (B0..BF) are not set properly after
the record is processed.
The point is, that in 'base/src/rec/recMbbiDirect.c' (still 3.12.2!)
'refresh_bits()' is called "too early" (before VAL is set to the new value).
After aplying the following patch, all seems to work fine.
---- 8< -------------------------------- snip -----
*** base/src/rec/recMbbiDirect.c.ORIG Mon Nov 20 10:50:13 1995
--- base/src/rec/recMbbiDirect.c Wed Apr 10 12:36:35 1996
*** 224,227 ****
--- 224,230 ----
else if(status == 2) status = 0;
+ /* VAL is now set properly, set the bitfield */
+ refresh_bits(pmbbiDirect); /* 10 Apr 96 12:30 by birke */
/* check event list */
monitor(pmbbiDirect);
*** 287,291 ****
if (pmbbiDirect->pact == TRUE){
status=(*pdset->read_mbbi)(pmbbiDirect);
! refresh_bits(pmbbiDirect);
return(status);
--- 290,294 ----
! /* refresh_bits(pmbbiDirect); not a good idea, VAL is not yet set */
return(status);
*** 298,302 ****
if (pmbbiDirect->simm == NO){
return(status);
--- 301,305 ----
return(status);
*** 308,312 ****
pmbbiDirect->val=pmbbiDirect->sval;
pmbbiDirect->udf=FALSE;
status=2; /* dont convert */
--- 311,316 ----
! /* will be done in 'process' */
! /* refresh_bits(pmbbiDirect); */
----- 8< -------------------------------- snap -----
Comments welcome ...
So long,
Thomas
_______________________________________________________________________________
Thomas Birke BESSY II (+49)-30-6392-4934 (fax -4859) [email protected]
http://www.bessy.de/~birke
HTML tools Mark Rivers
Proposed stepper motor code modifications Ric Claus
<1996>
2025
re: HTML tools Mark Rivers
<1996>
2025
