1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: vxWorks variable device support
To: [email protected]
Date: Fri, 12 Apr 96 13:55:41 HST
Dear all,
  There is vxWorks global variable device support for ai, ao, longin,
longout, stringin and stringout records. The vxWorks global variable is
the same as that of the record but omitting characters up to and
including the first ":" (if any) and characters including and after the
last ";" if any. Thus record name "ppp:var;sss" corresponds to variable
"var".
  I have a project where I want to hook up to quite a lot of vxWorks
variables in some legacy software. Some of the variable names are quite
long. Other variables are structures and I would like to define new
globals which are the addresses of interesting bits of these
structures.
  I propose extending device support to make use of the INP and OUT
fields and to use an INSTIO string to hold the variable name (36
characters are available) plus to support a leading "*" character to
force an extra dereference. If the field is not INSTIO, existing
behavior will occur, so the change is upwards-compatible.
  One could also support trailing "[n]" or "+n" syntax to reference the
nth element of an array or at a byte offset of n. Is this worth it?
  An example: the string "fred" used on an ai record references the
double stored in fred; the string "*fred" references the double pointed
to by fred (cf. C "double *fred"); the string "*fred[2]" references the
third element of the double array pointed to by fred; and so on.
  Has anyone already done something similar or have any comments on the
above proposal?
  William
Prev: Remote Camera Control Jeffrey J. Gross
Next: Re: vxWorks variable device support Andrew Johnson
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
