1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: fallback CA servers?
To: [email protected]
Date: Fri, 3 May 1996 18:36:31 +0100 (GMT)
William Lupton wrote:
> >   We are discussing how to handle simulation both when IOCs are present and
> > when they are absent. For simulation at other sites we are writing a Unix
> > CA server which emulates part of our VME database. For simulation at the
> > telescope we are toying with the idea that we might run the Unix CA server
> > all the time but that connections to it would only be used when the vxWorks
> > CA server was not running.
If you know that the Unix CA server will always be running, you could
always have the Unix server reflect PVs from the IOC into a different
namespace, and have all your clients attach to the Unix names and never to
the original IOC names.  This way the Unix server knows exactly when it
needs to be a simulator (because it gets connect and disconnect messages
from the IOC), and the clients couldn't care less if an IOC gets turned
off because they're never talking directly to it. There will be a
performance hit here of course, but for slow records it shouldn't matter.
If you were really clever you might even be able to automate it, so that
if a client requests a PV from the Unix server which the Unix system
doesn't actually have a value for, it could do a name translation and send
the request out to the real IOC, waiting for a response from the IOC
before it responds to the client connection request.  Don't know if this
would work or not, but it's an interesting idea.
I would agree with Steven Beard's comment though - you probably ought to
have to do something explicit to enable a simulator, or at least have a
big switch somewhere which disables all simulation for use during the
night.
- Andrew
  O o ._    Andrew Johnson, Royal Greenwich Observatory
     __\\_	Madingley Road, Cambridge, CB3 0EZ
  __|ooooo|__	Tel +44 (0)1223 374823  Fax 374700
~~\_________/~~	WWW http://www.ast.cam.ac.uk/~anj/
Prev: Re: simple questions Jeff Hill
Next: Re: fallback CA servers? William Lupton
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: fallback CA servers? Jeff Hill
