1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Building TCL/Tk interface to CA
To: [email protected]
Date: Tue, 7 May 96 10:07:25 CDT
The most recent version of Tcl/Tk is 7.5/4.1, released in late April
1996.  However, BLT development seems to be lagging a bit behind, in a
confused state.  (BLT 1.9.0 is reported to work only with the beta
version of 7.5/4.1 Tcl/Tk.  I can't get it to compile with final
release version 7.5/4.1.  Don't be confused by BLT 2.1 which only works
with tcl/tk 7.3/3.6.  BLT 2.1 is the work of others attempting to
upgrade, but hasn't not kept up with the current major re-write of Tk.)
Fall back and regroup.
Better to try the combinations (released in 1995):
  package	version	site
   tcl 		7.4	ftp.sunlabs.com/pub/tcl
   tk 		4.1	ftp.sunlabs.com/pub/tcl
   tcl-dp	3.4	ftp.cs.cornell.edu/Info/Projects/zeno/Software
   BLT 		1.8	ftp.cs.uoregon.edu/pub/jhobbs
The first three compile and install with the standard sequence
 		./configure; make; make install
The only modifications I had to do to get BLT going were to fix
some paths in the Makefile after the ./configure step.
(I choose to install BLT in /usr/local/lib/blt-1.8 instead of
the default /usr/local/blt)
Also, copy the BLT src tree into /usr/local/lib/blt-1.8/src
since tclCa will need at it.
Up till now, you haven't needed to pay attention to any
EPICS-related stuff.
Then, to compile the tclCa, modify Makefile.Unix to identify the
paths to where you've got tcl/tk/dp/blt and modify both
Makefile & Makefile.Unix to target your EPICS installation properly.
Doggone it now, this should work.
Pete [email protected]
UNICAT
Prev: Re: Building TCL/Tk interface to CA Kay-Uwe Kasemir
Next: Re: Building TCL/Tk interface to CA Steve Lewis
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
