1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA questions
To: EPICS Tech-Talk list <[email protected]>
Date: Fri, 24 May 1996 11:43:23 +0100 (GMT)
Two questions, which I guess are in Jeff Hill's area of knowledge but
others may know:
1. Is it possible to run the CA client layer on a vxWorks system which is
*not* an EPICS IOC?  Would this be an easy thing to do, or is the vxWorks
client too closely integrated with the server and database code?  At a
first glance it's not as simple as just loading caLib because that has
other link dependencies.
2. Is the host client layer thread-safe (I guess this depends on the host
OS ?) -- i.e. can my applications dedicate a separate thread to run
ca_pend_event, or even have multiple threads calling other CA routines?
What would happen if I called ca_pend_io?
Thanks in advance,
- Andrew
  O o ._    Andrew Johnson, Royal Greenwich Observatory
     __\\_	Madingley Road, Cambridge, CB3 0EZ
  __|ooooo|__	Tel +44 (0)1223 374823  Fax 374700
~~\_________/~~	WWW http://www.ast.cam.ac.uk/~anj/
Re: CA questions Jeff Hill
Prev: CHEP-97 pre announcement Matthias Clausen DESY -MKV2/KRYK-
Next: Burt compile. MURANAKA Masaki
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CA questions Jeff Hill
