1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS PostScript Documents (Addendum)
To: [email protected]
Cc: [email protected]
Date: Thu, 30 May 96 19:09:33 +0200 (MESZ)
Operat.System:HP-UX A.09.05 A
Mailer: Elm [revision: 70.85]
Addendum/Erratum to previous message:
Further investigation of modified Frame 5.0 letter  documents showed:
(*)  /FMAllowPaperSizeMismatch true def           allows to print a letter
	document on an A4 Printer, but our HP LaserJet 5si still requires
	manual intervention (i.e. press panel buttons). In this respect
	using the filter is more convenient.
(*)  papersize  999.9  999.9  worked with  Frame 4.x documents but causes an
	unacceptable page offset for a new Frame 5.0 test document.
	Therefore              "unknown"   and "999.9 999.9" in the filter
	has to be replaced by  "common area" + "595.3  792".
Sorry for these imprecisions. For clarity I will attach the modified filter.
Regards, Roland.
#!/usr/bin/awk -f
# Purpose: make Frame Postscript docs  as is printable on any paper format
# Remove papersize checks and instructions from Frame  letter/A4 documents
# FMBEGINPAGE/FMDOCUMENT
# Change papersize from            letter    to   common area
/612[ \t]*792/       {sub (/612[ \t]*792/,       "595.3  792") }
# Change papersize from              A4      to   common area
/595\.3[ \t]*841\.9/ {sub (/595\.3[ \t]*841\.9/, "595.3  792") }
# Search Frame Failure Routine, Delete "Print Error Message and Abort" Commands
# delete eventually included  PPD (PostScript Printer Description) Instructions
{if (/^\/FMFAILURE \{/){
		print;
	getline;print;
	while(!(/\} def[ \t]*$/)){getline;}
		print;
}else if (/^\%\%BeginPaperSize/){
	while(!(/\%\%EndPaperSize/)){getline;}
}else{
		print
# End of script
                                                             ___o
Roland M"uller                                             _`\ <,_
                                                    _____ (_)/  (_) ____
BESSY  I:       Abt.Maschine, Lentzeallee 100  : Phone (+49 30)82004 114
                D-14195 Berlin  (Wilmersdorf)  : Fax:                103
BESSY II:       Geb. 15.1, Rudower Chaussee 5  : Phone (+49 30)6392 4652
                D-12489 Berlin    (Adlershof)  : Fax:               4632
Mailbox :       [email protected]           :
*:Berliner ElektronenSpeicherring-gesellschaft f"ur SYnchrotronstrahlung
Prev: subscribe Dave Gurd
Next: driver support for snmp management Matthias Clausen DESY -MKV2/KRYK-
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: subscribe Steve Hunt
