1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: New database.
To: [email protected]
Date: Mon, 03 Jun 1996 10:45:38 -0500
MURANAKA Masaki wrote:
> New database on R3.13.0alpha3 makes much connection between host and
> IOC when the IOC reads its database. This is confirmed easily by
> netstat (8). Some Unix system will exsorst its network resources and
> will make the IOC error.
> Sometimes I had a trouble when IOC reads the database.
> This problem isn't always fatal, but I think it shuold be solved.
>                                                         from monaka
This happens if the database contains include statements.
The utility dbExpandInclude was created to solve the problem.
Thus the ioc should be loaded with the output of dbExpandInclude rather
than the original databases.
Another solution is to use NFS.
Marty Kraimer
New database. MURANAKA Masaki
Prev: Re: SNL/SEQUENCER 1.9 not backwards compatible Tim Mooney
Next: versioning convention Johnny Tang
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: New database. MURANAKA Masaki
Next: Viewgraphs from EPICS Class Jackie Wallis
