1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: PC-port status
To: [email protected]
Date: Thu, 6 Jun 96 15:59:02 MDT
----- Begin Included Message -----
>From [email protected] (Kay Kasemir) Thu Jun  6 15:44:44 1996
X-Sender: [email protected]
X-Mailer: Windows Eudora Light Version 1.5.4 (32)
Mime-Version: 1.0
Content-Type: text/plain; charset="us-ascii"
Date: Thu, 06 Jun 1996 15:44:41 -0600
Content-Length: 4764
>Current status of the EPICS -> PC port
>The first goal was to port the IOC (target) portion of EPICS
>onto a PC, using VxWorks 5.3 Tornado on a Pentium PC running NT4.0
>as the development platform.
>While some parts of the EPICS _host_ software are already ported to NT,
>this was done using a MS C compiler with specially build new
>Makefiles ("Project-Files"?). Because of the huge number of Makefiles &
>Shell-scripts used to build EPICS, I tried to use them instead of being
>forced to write new project files.
>While Tornado comes whith GNU make + bash (Born again shell), it turned out
>that Tornado-make calls $(SHELL) with "/C", which is ok for the default
>SHELL=cmd.exe but prevents using SHELL=bash.
>Fortunately I found a rather complete GNU-suite at Cygnus
>(http://www.cygnus.com/misc/gnu-win32) containing gcc, bash, make,
>bison, ....
>The additional benefit was the included gcc, the fact that the Cygnus-bash even
>emulates soft-links ("ln -s") that many Makefiles use, and a partial
>complete clib:
>    "The second part of the project (which we are currently in) is developing a
>     C library that is enough for GNU programs (fileutils, sh-utils, textutils,
>     bash, make) to be compiled on a Win32 system without any modification
>     to those programs. From their point of view, a Windows NT box is no
>     different than any other Unix box."
>This clib already allows you to call socket(), bind(), gethostbyname(), fork(),
>getpid(), ... so I was not only able to use the current Makefiles & scripts,
>in addition I could also build e.g. antelope and the other small tools that
>are needed on the host to compile the target portion of EPICS.
>Basically I only needed to provide new config files CONFIG.Vx.pc486,
>CONFIG.Unix.NT
>(because with Cygnus-gnu makes NT look like a flavor of Unix) and change
>all executables' filenames in the Makefiles from "foo" to "foo$(EXE)" with
>EXE=.exe  (Cygnus gnu also uses .exe-postfixes for executables).
>The current state is that I managed to
>1) compile the target portion of EPICS
>2) load a simple database onto a PC 100MHz Pentium target
>It's like the "makeExampleApp" database:
>             calc                               ai
>        |SCAN: 1 second          |            |                   |
>        |CALC:(A<B)?(A+C):D   VAL|---->-------| INP           VAL |---\
>   /->--|INPA                    |            |                   |   |
>   |  9-|INPB                    |            |                   |   |
>   |  1-|INPC                    |            |                   |   |
>   |  0-|INPD                    |            |                   |   |
>(This is not a new form of ASCII-graphical-dct but merely an illustration)
>The records are scanned correctly as I can tell so far, the calc record is
>ramping from 0 to 9.
>dbt results for the calc record (100 executions):
>100MHz Pentium    3550 +/- 74
>NITRO60 CPU       3625 +/- 74
>(The NITRO60 CPU is running the "older" EPICS R3.12)
>This result suggests that the PC target is at least as fast as a speedy
>VME-based CPU.
>You should also bear in mind that most 100MHz Pentium boards can also be
>equipped with
>a 120MHz, 150MHz,... CPU.
>Channel access is *NOT* working so far because of several differences in the
>byte order of the CPU 68k and Ix86 architectures. We are working on this.
>[email protected]
>Kay-Uwe Kasemir                 AOT-8, MS H820
>                                Los Alamos National Laboratory
>Tel. (505) 665 8891             Los Alamos, NM 87545
[email protected]
     ______| |______
    (______\_/______)
    (_\/_\_(X)_/_\/_)
          O'=`O
                                        \ o
                                          d
----- End Included Message -----
Prev: Software Engineering Position SIBLEY
Next: DBR_STRING get for DBF_DOUBLE (Possible Problem) Marty Kraimer
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
