1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: db2capsym and epics3.13
To: Epics Questions <[email protected]>
Date: Thu, 13 Jun 1996 11:25:16 +0100 (BST)
Rozelle asked me to forward this to 'tech-talk' for the
interest of others:
> Is 'db2capsym' specific to epics3.13?
> Cheers,
> Andy
No, It's not specific to 3.13 in terms of use, but it does need 3.13
dbStaticLib to build, and it uses .db files as input rather than .ascii files.
I have built capfast symbols for .ascii files I had for 3.11, but
I had to run them through sdr2recordtype first to get the .db files
I needed for the new tools.
In order to use all the features of dbt
including dumping records you also need the bug fix to dbStaticLib that
I reported last week and the bug fixes to dbStaticLib that Marty has
described in the epics www document found in the indexed title list as
"Bug and Fix Report Release 3.13.0Alpha3.", but you don't need
these fixes to use it for building edb.def files.
I originally built db2capsym under 3.12.2, you could probably go
back to that with a change of a couple of lines.
Rozelle
Prev: mv162 part deux John R. Winans
Next: EPICS port to Heurikon Baja47. David Barker
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
