1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: EPICS port to Heurikon Baja47.
To: [email protected]
Date: Fri, 14 Jun 96 08:45:38 MDT
It may be worthwhile to note that the accesses across the backplane
are only 4 times faster - while the soft ai record with no backplane
accesses were 50 times faster.
If your database is laden with algorithmic records - then you get the 50x speed
If you are doing mostly supervisory control - then you get the 20x speed
If is also worth noting - that the database processing is only a part of
the CPU utilization. The sequencer will get the higher performance improvement.
The higher performance could also be used for any other number crunching
analysis.
It may be useful to run Marty's stress test database and see what happens
with the channel access CPU utilization.
In either case, this is a nice performance improvement and a very useful
piece of data.
Re: EPICS port to Heurikon Baja47. watson
Prev: oops Paul Banta
Next: One button -> two actions with dm? swampler
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: EPICS port to Heurikon Baja47. Paul Banta
Next: Re: EPICS port to Heurikon Baja47. watson
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
