1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: SNL 1.9 troubles
To: [email protected]
Date: Fri, 9 Aug 96 17:20:58 CDT
There seems to be a bug in SNL 1.9 that won't keep variables in
separate tasks of the same sequence program separate.
Trying to load two instances of the following example SNL program.
pj:debug1 and pj:debug2 are flags (bo records) that turn on printing to
the VxWorks console whenever pj:ao1 or pj:ao2 (ao records),
respectively, are changed.
However, output appears when _either_  pj:debug1 or pj:debug2 are set to 1.
That is:
  set pj:debug1 to 1 and pj:debug2 to 0, then change pj:ao1, you get output.
  set pj:debug1 to 1 and pj:debug2 to 0, then change pj:ao2, you get output.
  set pj:debug1 to 0 and pj:debug2 to 1, then change pj:ao1, you get output.
  set pj:debug1 to 0 and pj:debug2 to 1, then change pj:ao2, you get output.
  set pj:debug1 to 0 and pj:debug2 to 0, then change pj:ao1, no output.
  set pj:debug1 to 0 and pj:debug2 to 0, then change pj:ao2, no output.
Now this code is not using any escaped C code so I shouldn't
need to reference variables as "pVar->old_v" and such.
Also, the local variable "old_v" in each task seems to be shared, as well.
Something is screwy here.
Any help?
   Pete [email protected]
   UNICAT
-----------------------------% clip here %-----------------------------
program test
        ld < test.o
        seq &test, "name=test1, V=pj:ao1, D=pj:debug1"
        seq &test, "name=test2, V=pj:ao2, D=pj:debug2"
        td "test1"; td "test2"
option +r;
float   old_v;       /* saved value to check for changes in v */
float   v;
assign  v to "{V}";  /* ao record */
monitor v;
short   d;
assign  d to "{D}";  /* bo record, flag that turns on debugging output */
monitor d;
ss quick_test {
   state start {
      when () {
         old_v = v;
      } state idle
   state idle {
      when (v != old_v) {
      } state changed
   state changed {
      when () {
         if (d > 0) {
            printf("      from   %g   to   %g   \n", old_v, v);
        old_v = v;
      } state idle
} /* ss quick_test */
Prev: mv167/162 eproms Graham Waters
Next: Re: SNL 1.9 troubles William Lupton
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
