1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: "Edge sensitive" record processsing.
To: [email protected], [email protected]
Date: Fri, 16 Aug 1996 10:38:15 -0500
>I've got a situation where I need to cause a PV to process when a second
>PV makes a transition in one direction.  In otherwords, I need to fire
>PV1 when PV2 changes state 1->0, but not on the 0->1 change.  If it matters,
>PV1 is a BO to a GPIB device.  A particularly ugly GPIB device, at that.
>I'm sure I've seen this done (short of writing a state machine in SNL),
>but it escapes me.  Probably just another case of "Berkeley Brain Rot."
I have not looked at a database in a long time, but...
Would not the scan disable take care of this?  You could simply set PV1's
disable value to be 1 from PV2 and then forward link from PV2 to PV1.
--John Winans
Prev: Re: "Edge sensitive" record processsing. S. Joshua Stein
Next: Project Status Bob Dalesio
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
