1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: rec/devSup advise needed
To: [email protected]
Cc: [email protected]
Date: Tue, 20 Aug 1996 12:33:28 -0700
I'm writing driver, device and record support for a set of custom VXI
modules.  These modules have several functions, but share a number of
things like a subset of the VXI A16 registers, interrupt handling, etc.
Because of the desire to keep things self consistent and efficient, I
created one record type per module type.  This makes for fairly messy
device support, as there is a lot of checking going on to figure out
which record field changed that caused the record to process.  Does
anyone have a cleaner way to deal with this?  Perhaps something to the
effect of using RSET->special to figure out which field caused
processing
and using that information (somehow) to tell RSET->process which
DSET->process
function to call?  Perhaps call DSET->process in RSET->special directly?
  Second, the records properly handle Is and Os from/to the modules when
they are marked scan passive.  However, the modules can also raise
interrupts when they detect faults.  I would like to get that
information
into record fields for display on an operator screen.  Setting up for
the I/O Event scan mode appears to lock out processing due to
modification
of record fields from operator screens.  Calling db_post_events from the
ISR seems to have no effect.  There is really no need (currently) to
call
the process routine, but the record must be updated.  What is the proper
way to handle both of these modes of operation?
  Currently I'm running 3.12.2 and will upgrade to 3.12 as soon as I get
a chance.
		Ric
	Ric Claus	([email protected], (415) 926-2697)
Re: rec/devSup advise needed Gabor Csuka
Re: rec/devSup advise needed Ric Claus
Prev: Re: ANL vxWorks 5.2 Bakul Banerjee
Next: tclCa package (was et_wish) Claude Saunders
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: R3.13.0beta1 available Marty Kraimer
Next: Re: rec/devSup advise needed Gabor Csuka
