1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics driver & device support for IP modules
To: Bill Brown <[email protected]>
Cc: [email protected]
Date: Wed, 21 Aug 1996 18:45:11 +0100 (GMT)
On Wed, 21 Aug 96 09:47:52 PDT Bill Brown <[email protected]> wrote:
> Perhaps some discussion of creating a "standard model" for supporting IP cards
> under EPICS might be in order.  As the IP interface (including module
> identification) seems to fairly well specified, perhaps we could take advantage
> of that information in the system configuration and initialization process.
> Any ideas?  Is this worth spending some time on during the next epics meeting?
Hideos uses one "standard model" for supporting IP cards providing you
are using C++ and an MVME162; I have already developed another which works
in straight C and also supports other IP carriers.  You may already have
my code, as it's used by the CANbus driver which is in some of the recent
distributions - have a look for base/src/drv/ansi/drvIpac.c.
Documentation is available under http://www.ast.cam.ac.uk/~anj/epics/
My model involves having a driver for each type of carrier board, the
standard drvIpac.c driver then uses these to control all of the carrier
boards installed, and provides services to any module drivers which talk
to the individual IP modules.
I don't attempt to do auto-configuration; you have to put something into
the startup script to introduce each carrier board (on the 162 this would
be simple, but it gets *much* harder with external IP carrier boards). My
canBus driver also requires you to explicitly introduce each IP module as
well -- it should be possible to create an IP module driver which scanned
all of the IP slots to find instances of the modules it supports, but if
there is any other configuration needed for these modules I think it's
better to be explicit about their whereabouts.
By the way, has anyone out there tried the drvIpMv162 carrier driver yet?
Does it work?
- Andrew
  O o ._    Andrew Johnson, Royal Greenwich Observatory
     __\\_	Madingley Road, Cambridge, CB3 0EZ
  __|ooooo|__	Tel +44 (0)1223 374823  Fax 374700
~~\_________/~~	WWW http://www.ast.cam.ac.uk/~anj/
Prev: Re: epics driver & device support for IRM Bill Brown
Next: Re: rec/devSup advise needed Gabor Csuka
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: epics driver & device support for IP modules Matthias Clausen DESY -MKV2/KRYK-
